water in rad vents
What is the cause of left over water in radiator air vents? I have a one pipe system - no water hammer or noise but have water in some of the rad vents. Any thoughts would be appreciated.
Thanks,
  • conversiontime
    conversiontime Member Posts: 87
    spitting water?
    If the vents are spitting water during cycle, then wet steam is likely the culprit. IMO dry steam will cause the vents to hold a tiny bit of water once the boiler stops firing and steam condensates. Every rad vent I have ever removed held a tiny bit of water upon inspection whether by design or fault, I do not know.
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,917
    Some is normal.
    Pushing warm, damp air through a cold metal vent, you have to expect some condensation.
