Dunkirk90-200
Zakrzewski
Member Posts: 2
I am having trouble with my 2 year old boiler. Started with a E02 error. Replaced igniter and took several restarts to fire Worked for a few days and now a E03 - gas valve disconnected. I checked the wiring and it is ok. Can't get an accurate voltage reading as it goes to the error too fast but looks like voltage is changing
Bob Boan
Q90
Hi I'm a Technical Support Rep at Dunkirk. Are you sure you have a Q90-200 and not a Q95M-200? The Q90-200 doesn't display error codes. The 95M does. If you need further assistance, feel free to call us at 1-800-325-5479.0 -
Q95M
Sorry you are correct. Thanks. I spoke with a tech at ecr that was very professional and helpful. I have a local heating contractor stopping by on Thursday and will let you know the results0
