Gianonni Direct DHW experience needed.
Mark Eatherton
Member Posts: 5,875
Wallies,
I am dong a DHW project in an area with extremely hard water (20 grains). One of the proposed systems is a Gianonni based direct water heating boiler with appropriately sized storage. While I like the concept, and the manufacturer has assured me they have installations done in hard water conditions that are performing flawlessly, I'd really like some contractor feed back from the real world.
Anyone care to chime in?
How long has it been running?
What kind of water conditions (hardness, sodium or other minerals present?)
Thanks in advance.
ME
Thanks in advance.
ME
Some experience
Hi Mark
We stopped using gianonni some time ago due to some premature failures of heat exchangers
We have some aggressive water in some areas of southern Maine including some public water systems which can create huge build ups on tankless style heaters requiring annual flushing
Our solution has been to use high grade stainless tanks on all our DHW installs
We find it to be a more sustainable solution
Good luck
JimThere was an error rendering this rich post.
Thanks Jim G
Anyone else?
Also, Jim, were these actually being used as an open loop heater, running potable water through the boiler HXer or were they used with indirects (reverse or otherwise).
TIA
ME0 -
Gianonni
Mark,
I've always had reservations about the Gianonni because of its narrow passageways and high head. A lot of heat transfer in a small area that works great until scaling or fouling enters the picture.
I've never dealt with one on an open loop, but we recently replaced a two year old Munchkin Contender that was connected to 8000 ft. of non-barrier pex on a radiant floor (90% staple up). The Gio was leaking like a sprinkler. A job we were called in on that we're still trying to correct.
I'd avoid it on an open loop like the plague.Bob Boan
Closed loop
Hi Mark,
they have all been closed loop boilers we had problems with
I find they are not a very sustainable product
here is one we show our clients to compare quality
good luck
jimThere was an error rendering this rich post.
Closed loop
Hi Mark,
good luck
- 119 Chimneys & Flues
- 76 Pipe Deterioration
