Boiler stand for TT boiler
bob eck
bob eck Member Posts: 930
Hi I am looking for a boiler stand for a Triangle Tube Challenger Combi boiler. I know Triangle Tube offers one just checking to see if there is one made that is priced a little more competitive than the one TT offers.
    hot_rod Member Posts: 27,183
    edited November 2012
    www.phpinc.us
    I think still builds stands
  • Zman
    Zman Member Posts: 7,611
    Has anyone?
    Has anyone tried running unistrut from floor to ceiling? I would think 2 struts would be stiff enough. The top and bottom would obviously have to be anchored to concrete or framing. The hanging bracket would be better if it were through bolted, so it can't slip.
    Albert Einstein
  • Larry (from OSHA)
    Larry (from OSHA) Member Posts: 743
    this stuff is great
    http://www.8020.net/
    give them a design and they will build it or buy material and you do it.  really works well.
  • TonyS
    TonyS Member Posts: 849
    We usually build a wall
    Shoot a plate down and screw one in overhead with a few vertical studs,1/2 inch ply and a couple coats of grey floor paint.
    Gets you started with a flat level surface that you can screw your bell hangers and split ring stands to.
    Also is nice to hide your wires behind and mount pumps.
