Hanging ductless condenser on wall
TonyS
Member Posts: 849
Normally I keep my condenser 1 foot or more from a wall. But I have noticed many wall hung units just 4 inches away. I have a job where mounting them close would be advantages. Any Ideas or suggestions here?
wall mouting installs
I have installed a few using the wall mounting kit and on short lines sets you may end up with a harmonic vibration espically on residental wood frame homes but on commerical w concrete wall we had no issue just thought i would give you a heads up on it to help you maybe avoid a issue I have never had a vibration issue when just setting them on a pad though peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Check the install manual
For your manuf clearances. I use the wall brackets and try to get as far off the wall as possible. My unit(s) could be mounted 4" from the wall. Also, check for minimum line set requirements. The resonance Clammy is referring to may be the compressor tearing itself up.0 -
read the instructions
Not to start anything but the mitz that i spoke about with the harmonic vibration is not the compressor tearing itself up other wise it would still not be working perfectly being it has been in for about 2.5 years this is a heat pump unit and it has this vibration weather it is in heat or cooling mode ,The wall it is attached to is only wood fame and basicilly was a former chicken coop(from late 1800 on histroric revolutionary sitre) turned into a labatory with some real crappy framing but there wsa no choice of placement except wear we had put it .The line set is also at the miniun that mitz states which i believe is about 12 ft .The vibration is extremely small and has been unnoticable by the workers ,owner and my partern who did not notice until i pointed it out and still my buddy had to really sit close to even notice it .On a side note this unit serves a lab that has a mass spectrim alyz and other big buck test equiptment including ovens and hi temp heaters for testing .The mounting info i had given was just a heads up to help some one maybe prevent them from doing a job twice but only get paid once peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Didn't mean to accuse, Clammy
With Fujitsu when the inverter units first came out we were told that "to short" a line set could cause harmonics. A year or so later, in conversation with a factory engineer, I asked what caused the harmonics. He said it could be the compressor wearing prematurely. Fujitsu does have minimum line set recommendations . Not sure on Mitsubishi and others. No offense meant!0 -
none taken
None taken ,the one that did have an issue was the only one yet so far but i only have installed mitzs invertors as of the last few years and i have stayed away from the other players , it has been at least 20 years since i have installed a different brand .I have work on a few by others and mostly the promblem with them where inproper installation like no pressure testing ,vacume and the rest of the issues that come from the fly by nite low ballers but that comes with the cheapen price .I really don.t install many of them being if you want the whole job to look professinal (hide a lines)and not like a eyesore it costs plus when your looking at doing 3 or 4 second floor bed rooms and all those line set running on the exterior of the home it's some times easier and cheaper to just do a nice central system .Peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Hanging
Two things.The min line set lenght is to allow the metering device some room to work ,to even out the freon flow before it gets back to the comp.And the outdoor unit being so close to the wall causes the hot discharge air to be sucked right back into the air inlet side raising the hi side press.And a third thing, it makes it a little tougher to wash the cond coil for those who do wash the cond coil.0 -
Choose wall-mounted
Hello Friends,
If you have one or more rooms without exterior walls or windows, a wall-mounted ductless split system will work beautifully. The indoor air handler is sleek, unobtrusive and quiet.
Thanks and Regards,
Steve Holmes0 -
Appreciate your input Holmes
but we are talking about hanging the condenser unit on an outside wall instead of setting it on the ground. A lot of good points being made here, I appreciate all the comments.
Thanks0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
