How was this put together!
Here's an old system i came across. I had to dismantle it and remove it. Weight about 450-600. I had to make 30ish cuts. Two manifolds on one side. 3/4 black iron pipe with elbows on the other side. Couldn't figure out if the pipe was cast into the manifolds or thread in. When we removed the pipe from the manifolds we bent them out. But they still had threads? Any ideas?
  • JStar
    JStar Member Posts: 2,752
    Pipes
    The opposite ends of the pipes has reverse threads. One side clockwise, the other counter clockwise. Why did you rip that out?
  • Maveric79
    Maveric79 Member Posts: 2
    It had a small small pin leak and the customer wanted to add a doorway there. so we need to go back and put in two separate radiators on either side of that.
  • JStar
    Rad
    Too bad. I would have put that in my shop.
  • kcopp
    kcopp Member Posts: 4,628
    that was a .....
    work of art.... and it threw out a ton of heat to boot.
