Radiator Repair Sucess!
H3809
Member Posts: 19
I'm new to the steam heat world, and stumbled across this website, picked up Dan's book "We got steam heat!" and I'll be ordering more books soon. I have a one pipe steam system, and thanks to the book and here I have already found a slew of problems...bad vents (main and radiator) copper pipes in the middle of iron pipe runs, no hangers in the basement or insulation for that matter..no pitch to any radiators, leaky pack nuts, and a cracked beautiful radiator. (I'll post a picture later, its tall on the ends, short in the middle, looks like it was used as a bench)
I wanted to share a success story of repair, I read it in we got steam heat and on-line as well. I picked up JB Weld Steel Stik. Its worked great! (so far) Much better than dealing with the tubes of two compounds. Just kneaded it together and worked it into the crack and surface (with proper prep-work of course) It dries metallic color and stayed mailable so i could indent lines to match up with the detail work on the radiator.
I'm really pumped to have steam heat now, and learning all about its kinda addicting...
Thanks for the help do far this site has been while I've been lurking, I'm sure I'll have questions down the road, and good luck if you try to repair your radiator!
Congratulations
hopefully you have saved that great old radiator from the scrap pile. We really want to see a picture of it.0 -
Sounds like a window radiator.
See the radiator on page 43 of this catalog. It probably doesn't look just like it, but the idea was to sort of wrap the radiator around the window.Just another DIYer | King of Prussia, PA
Yes!
That is it exactly! (it might even be the same manufacturer) I'm sorry it took so long to get back I've been having some log on issues. I took some pictures and will post them tonight.0 -
beautiful!
People will surely ask why it's shaped that way. You could tell them the truth -- or just call it the "Hot Seat."0 -
Some days
I could see myself curled up on that thing with a good book. :-)Just another DIYer | King of Prussia, PA
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
