Burnham Freedom error code 12
Jbyrd
Member Posts: 4
in Gas Heating
Hi have a Burnham Freedom error code 12 been a recurring problem for a few months now boiler wont restart. I already verified 24 volts and the pressure is fine. Any help would be great. Thanks
E12
That is the code for a low water condition. Have you checked the LWCO for proper operation?0 -
Burnham freedom error code 12
Hi Joe Thanks for the reply. The water pressure is fine. I tested water sensor its fine checked fuses and verified the 24 volts to transformer. Any other suggestions would be great I was just hopeing someone ran across this issue and new exactly the issue. This seems to be a problem with these early models. Thanks0
