If our community has helped you, please consider making a contribution to support this website.  Thanks!
Burnham Freedom error code 12
                    Jbyrd
                    Member Posts: 4
                                  in Gas Heating
                    Hi have a Burnham Freedom error code 12 been a recurring problem for a  few months now boiler wont restart. I already verified 24 volts and the pressure is fine. Any help would be great. Thanks
            E12
 That is the code for a low water condition. Have you checked the LWCO for proper operation?0
            Burnham freedom error code 12
 Hi Joe Thanks for the reply. The water pressure is fine. I tested water sensor its fine checked fuses and verified the 24 volts to transformer. Any other suggestions would be great I was just hopeing someone ran across this issue and new exactly the issue. This seems to be a problem with these early models. Thanks0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 5.7K Gas Heating
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 49 Job Opportunities
