Viesmann Riello Burner Purge Cycle
TimC
Member Posts: 4
I have a Viesmann Vitola Biferral BEA-18 purchased in 1990 with a Riello Mectron M3 oil burner and a E/KR-120 (Viesmann) controller.
This unit has been fantastic all these years and still looks new. Normally, the burner goes into a 10 to 15 second purge cycle, and then ignites. Lately, the burner is skipping the pre-purge cycle and the burner ignites immediately. It runs fine but I'd like to replace whatever it needs. Any expert opinions?
No purge
Can you think of any changes to the system, such as a new thermostat?--NBC0 -
None
No changes whatsoever...0 -
only 2 causes I have found
One would be in the stem or ball for the cut off in the pump, other could be the control. I would have a tech check it out. I still have one of the first BEA-46 units out there.0 -
What is the stem or ball in the pump? Is that a pump replacement issue or a separate part. I'm thinking it is the controller. I talked with a friend today who is a plumber and he said that Riello is a good company to call and they will talk to you. I bought my Viesmann from the guys on This Old House back in the late 80's and early 90's when I saw them install one...I was in the process of building my own home at the time and no one had heard of the brand at the time. I've installed 5 of them over the years in friends homes...0 -
simple test
remove the coil from the stem and put a metal screw driver in it. Start the burner. If it fires with that off, replace the pump, if not, replace the control. No repairing either of them0 -
If It Is The Pump...
If it is the pump that is bad, why would there be ignition (spark) immediately as well. Doesn't this point to the controller? I can see a bad pump spraying immediately but normal ignition does not start for 10 to 15 seconds...just thinking...0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
