weil mclain service
goat
goat Member Posts: 6
How often should I have my gas ultra serviced? had it put in 3 yrs ago. Also how important is the ph. level for the furnace.
  • kcopp
    kcopp Member Posts: 4,630
    You're due....
    If its LP its a good practice to have it torn down and cleaned yearly... Natural gas you can get away w/ every year. Someone should do a look see at the boiler every year to assure that all is running well and that nothing is leaking.
  • SWEI
    SWEI Member Posts: 7,348
    pH
    Is critical with an aluminum HX.
  • Steve Whitbeck
    Steve Whitbeck Member Posts: 669
    Ultra
    What Kcopp said.  You are over due.
    If the aluminum heat exchanger gets plugged it is a bugger to get it clean.
