weil mclain service
goat
Member Posts: 6
How often should I have my gas ultra serviced? had it put in 3 yrs ago. Also how important is the ph. level for the furnace.
You're due....
If its LP its a good practice to have it torn down and cleaned yearly... Natural gas you can get away w/ every year. Someone should do a look see at the boiler every year to assure that all is running well and that nothing is leaking.0 -
pH
Is critical with an aluminum HX.0 -
Ultra
What Kcopp said. You are over due.
If the aluminum heat exchanger gets plugged it is a bugger to get it clean.0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
