Weil-McLain LGB Steam Boiler Sooting Up
ssmh
Member Posts: 8
We are an HVAC company and are experiencing a Weil-Mclain steam boiler model # LGB which is sooting up and giving off carbon monoxide readings. Recently, we found the inside of the vertical chimney collapsed and a stainless liner was installed. Do you have any suggestions.
Boiler
Do you have a combustion analyzer? What are your readings? Are the sections clean and free? The chimney is lined right niw?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
