ez gas
Paul Fredricks_3
Paul Fredricks_3 Member Posts: 1,556
We have a customer with a Smith 8, converted to gas using a Carlis EZ Gas. The basement flooded out with sea water. What do I need to replaced on the burner? Not really familiar with these yet.
  • JStar
    JStar Member Posts: 2,752
    Flood
    How high did the water get? Anything covered by water needs to be replaced.
  • Paul Fredricks_3
    Everything
    Looks like he'll start fresh. It had flooded before when the Smith was oil. Replacing the burner components did the trick then, just didn't know with the gas burner. This time he'll gor for a boiler with indirect.
    Thanks
  • JStar
    Flood
    You can probably make everything work, but at what cost? When gas valves get wet, they tend to stick open. And electrical parts have a habit of catching on fire. Not worth it! Like you said, use this as an opportunity to install a WALL HUNG boiler. High and dry.
