Need help badly
Rice
Member Posts: 18
Hi. I am a contractor that is building his own home. I had pex supply engineer my radiant system and I already have my 3 zones of pex run and my ao smith vertex water heater installed. I am fairly good at plumbing but canot find any sort of a diagram of how the pumping station should be plumbed. I hired a plumber and have half down but after I pointed out he forgot s traps on the sinks he left and now financially I'm stuck trying this part myself. Any help would be appreciated as I'm hoping to move my family in by Christmas. I do know pex gave me 3 taco zone valves and a heat exchanger and two pumps. I have several other parts but those seem the key ones to tell
Plumber?
You hired a "plumber" that installed sinks with no p-traps? They designed the system, but didn't provide you with a drawing?0 -
Radiant
Pex supply.com engineered the system but only set material and yes the plumber seemed good and had good references from othe contractors but his work was horrible so now I'm kinda stuck trying to find a rough schematic for the pumping station.0 -
Contact Pex Supply
It's like hiring an architect, and having a lumber load dropped off at the site, with no prints. Whomever put that materials list together, had a specific plan in mind. Why re-invent the wheel?0 -
Heat
Where are you located?0 -
Radiant
Northern vt. I have a plumber coming through to sketch out a design based on what I have. I will post a pic to see if u guys think it looks right0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 980 Plumbing
- 388 Solar
