wood fired question?
Does anyone have any thoughts on setting up an outdoor food burning boiler connected to cast iron radiators as a gravity system?  If the power goes out (no circulator) but the fire remains going in the wood burner, could one with some creative plumbing, have a viable heat source?
On a day to day basis, the functionality of the device and radiators would be as designed.  I am simply asking the question about in an emergency (no power) situation.
  • Ironman
    Ironman Member Posts: 7,859
    question?
    If you have no power, what's gonna run the controls, draft fan and circ. on the wood boiler?
    It would be much easier to connect a generator to the wood boiler with the house boiler connected to the same circuit.
    Bob Boan
  • Ironman
    edited October 2012
    duplicate
    Bob Boan
    hot_rod Member Posts: 26,604
    I agree
    most of the wood burners shut down fairly quickly when the power goes out. Either a flapper door and or fan will shut down.
    Be sure all the door gaskets seal well so it doesn't have a source of air to keep the fire burning.
    If the boiler is outdoors and piped with pex into a building I'm not sure you would get much gravity flow thru 1" pex.
    Some wood burners add a small golf cart battery and UPS to keep a pump circulating for an hour or so while the fire burns out.
    I suppose it depends on how much $$ and technology you want to throw at a infrequent condition.
