Combination control bleeding
roman828
roman828 Member Posts: 1
Gas guy came out late last night because we smelled gas. He said the
"control was bleeding." No question about he said.  When I call to have the
repairman to call out, Do I state it like that or another way so I am not taken
advantage of. I am almost broke. I am crossing my fingers on who I should call.
Thanks.
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    edited October 2012
    Bleeding
    Did he leave a tag on the boiler with a written statement of the problem?
    What sort of system do you have?
    I hope no one will ever take advantage of you, however it will make it easier (less time), if the repair person has an accurate description of the problem.--NBC
