Sunrad EDR
eclark
Member Posts: 33
Bought a house last year that has mostly Sunrad (or sunrad style) radiators. I'm just trying to see how many EDR for the units, but can't find any guidance. Anybody know where I can get it?
Thanks,
Eric
Thanks,
Eric
Try This
Go to the section "Sizing radiation for steam boilers" http://www.comfort-calc.net/Steam%20Information.html0 -
There are
There are 2 sizes to choose from in this pdf from the library here.
M 5X20 is 2.25 EDR per section,
M 7.25X23 is 3.40 EDR per section
http://www.heatinghelp.com/files/articles/928/299.pdf0 -
The American Standard Catalog
gives those ratings as 2.0 ft.² and 3.0 ft.² EDR, respectively. I wonder why there's a discrepancy?Just another DIYer | King of Prussia, PA
Thanks guys
Reason I ask is because when we moved in, there were two places where radiators had been disconnected and removed. I have no idea why. If I find out that I've got only 275 SF of EDR installed but that my boiler has capacity for 360, I can reinstall those radiators without compromising the system, right?0 -
Heat Loss
Not only will it not adversely affect the system, if you do a heat loss of the areas they've been removed, you will probably discover they're needed.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
