STEAM
GREENTECH
Member Posts: 1
HAVE A STEAM SYSTEM THAT HAS A RISER WITH 2 FLOORS JUST 2 RADIATORS ONE ON EACH FLOOR THAT WILL NOT HEAT UP UNLESS YOU CRAN THE HEAT PASS 75 AND EVEN THAN IT GOES UP SLOW AT THAT RISER CAN IT BE DIRT ITS A ONE PIPE SYSTEM
If the vents are working
and the valves are fully open, there may be a water pocket somewhere in the piping to the riser.All Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
