STEAM
GREENTECH
Member Posts: 1
HAVE A STEAM SYSTEM THAT HAS A RISER WITH 2 FLOORS JUST 2 RADIATORS ONE ON EACH FLOOR THAT WILL NOT HEAT UP UNLESS YOU CRAN THE HEAT PASS 75 AND EVEN THAN IT GOES UP SLOW AT THAT RISER CAN IT BE DIRT ITS A ONE PIPE SYSTEM
If the vents are working
and the valves are fully open, there may be a water pocket somewhere in the piping to the riser.All Steamed Up, Inc.
Consulting0
- 120.3K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 31 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 152 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 737 Plumbing
- 5.2K Radiant Heating
- 357 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 70 Job Opportunities
- 14 Recall Announcements
