If our community has helped you, please consider making a contribution to support this website.  Thanks!
Oil To Gas Boiler Conversion
                    Heat
                    Member Posts: 2
                                  in Gas Heating
                    I am in the process of converting the existing oil boiler which is U.S radiator Corp red Top size A6, model # 64479. I am considering  the Columbia MCB series gas boiler. would you recommend I go with 75,000 BTU or 100,000 BTU input. My town homes heating area has 7 radiators & is approx. 1,000 sq ft.
Chris,
                Chris,
            Heat loss needs to be done
 Rad size and home soze doesnt dictate boiler size. Complete a heat loss calc and you will get you answer. Slant fin has a prettygood program.0
            You
 Have to calculate the heat loss of the structure. Then match the boiler according to that.If no one posts the link to the download of the calculator, I'll post it later, when I get home.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
