2pipe steam system vacuum breaker
I think I have a Webster 2 pipe steam heating system. It has on each recessed cast iron convector a 1/8 inch vacuum breaker with a tiny check ball. It was leaking steam and I was able to  use a pin to reseat the ball. What company makes replacement vacuum breakers?
Idle hands are the devils workshop
  • Rod
    Rod Posts: 2,067
    Vacuum Breaker?
    Hi-  I'm not familiar with these so I just wanted to give you a "bump" to the top of the page where more people will see your post
    You might also post a picture of the vacuum breaker as it might help identify it.
    - Rod
