2pipe steam system vacuum breaker
jeff klaverweiden
Member Posts: 58
I think I have a Webster 2 pipe steam heating system. It has on each recessed cast iron convector a 1/8 inch vacuum breaker with a tiny check ball. It was leaking steam and I was able to use a pin to reseat the ball. What company makes replacement vacuum breakers?
Idle hands are the devils workshop
Vacuum Breaker?
Hi- I'm not familiar with these so I just wanted to give you a "bump" to the top of the page where more people will see your post
You might also post a picture of the vacuum breaker as it might help identify it.
- Rod0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
