C.C.H
Techman
Member Posts: 2,143
This is an addon to the Luxaire Warranty thread. Bristol Comp Co also abides by the Rheem "max refrig in a system chart" for their entire residential line of comps.They vary from 6lbs of freon for a 62k comp and a 36k comp. But for a 42k they go upto 9lbs in the entire system. So use a CCH or don't use one ,thats your call. I really like being known for having comps that last and last and last.My longest surviving comp was a measly 30 years . so again ,you tell me!!!!!
An update, a Territory Manager for United Refrigeration said "off the top of my head it's about 9-10 lbs for Copeland". So again ,you tell me!
Bristol Comp
One more little fact, Bristol uses a CCH in their entire commercial line of comps.0 -
cch
There have been times I had to go install one on a few wta heatpump.You will find many of scroll out there without heater on them,.heck accumulator are going away as well.
They have to compete and boost those efficency numbers.0 -
CCH
Come on mech's .That 30 year running/surviving compressor that I alluded to was on a REFRIGERATION system , 365 day's a year after year after year , NOT a summer only AC unit. So one more time YOU TELL ME!!!!0 -
What gas?
Are these for current 410 units or for dry units?0 -
What gas
The Rheem chart is for r22 ,but I'm going to say I don't know if it applies to 410a, but now I'll have to go check that out.0 -
Rheem
I saw this in the I/O for their dry unit. I guess they figure the units will be overcharged in order to work with the who-knows-what ancient evap. But guys that do dry units on old coils aren't real likely to worry about how long the dry unit will last.0
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
