Peerless pinnicale
AFred
Member Posts: 81
Went on a no heat/no hot water tonight.
Its a PI-80rev1, It had a f31 error(parameter memory). The rep says replace the board.
I was wondering if anyone knew if any munchkin boards were interchangeable with the rev1 pinnacle? I might have an easier time getting a munchkin board.
Thanks
-Andy
Thanks
-Andy
Pinnacle
I believe that the only difference between the Munchkin and Pinnacle is the name. Everything else is exactly the same.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Pinnicle Vs. Munchkin:
I believe you are correct. The one big difference is that Munchkin parts are usually easier and cheaper to get.0 -
Pinnacle
That's the point, I have more options of wholesalers if I'm looking for munchkin parts. I know you can interchange the gas valves, blower, ignitor, flame sensor, ect. But peerless had 4 differant boards, I think. I'm not sure witch would be the same in the munchkin. I think its time to look up some munchkin manuals. I was hoping I would find somebody on here that has done this with the boards.
Thanks
-Andy0 -
Follow-up
I know you guys love to hear the story's end.
So I did find a Munchkin board that would be identical minus some stickers, at 80% of the price of the Peerless part. Heres the kicker, my wholesaler told me there would be no warranty on it. So I did find the peerless board in stock locally and it has a warranty.
Moral; Cover your butt!
-Andrew0
