Hot Water Loop to Steam Boiler
nycpa
Member Posts: 108
Hi,
I wanted to know if its possible to directly circulate the water from a steam boiler around the basement of my house without having a bypass loop or heat exchange. A plumber I talked to said I don't need any of those things.
Thanks
Thanks
Loop
Don't use that plumber!! Call a heating professional. Where are you located?
You need a bypass loop, at least, to maintain proper temperature in the pumped loop. A heat exchanger is not necessary on all applications.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
