Hot Water Loop to Steam Boiler
nycpa
Member Posts: 108
Hi,
I wanted to know if its possible to directly circulate the water from a steam boiler around the basement of my house without having a bypass loop or heat exchange. A plumber I talked to said I don't need any of those things.
Loop
Don't use that plumber!! Call a heating professional. Where are you located?
You need a bypass loop, at least, to maintain proper temperature in the pumped loop. A heat exchanger is not necessary on all applications.0
