Chemical injection hand pump
SWEI
SWEI Member Posts: 7,348
Any recommendations for a small pump to inject Rhomar into FHW systems?  I'm thinking if I inject right at the circulator output flange (Webstone w/ ball drain) while the pump is running, I can slowly add undiluted juice without having to premix (which gets to be a real PITA on larger systems.)
thanks~
