Chemical injection hand pump
SWEI
Member Posts: 7,342
Any recommendations for a small pump to inject Rhomar into FHW systems? I'm thinking if I inject right at the circulator output flange (Webstone w/ ball drain) while the pump is running, I can slowly add undiluted juice without having to premix (which gets to be a real PITA on larger systems.)
thanks~
thanks~
Force Hand Pump
Silver King force pump is very good. Make sure to rinse it with fresh water after pumping chemicals.
http://www.silverkingmfg.com/0
- 120 Geothermal
- 394 Solar
