Henry Ford museum radiators
John Mills_5
Member Posts: 952
Appears to be how they heat the joint. Not on the night I was there, the A/C was.
Looks like the rad on the left
has those pre-Monoflo tees- Eureka or similar.All Steamed Up, Inc.
Consulting1 -
Flow
I'm thinking the flow was left to right, no?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
