Would you call this short-cycling?
Gordan
Member Posts: 891
Outdoor temp 48 F, indoor temp 68 F, target supply temp 98 F. The TT Prestige Solo 60 fires for 3.5 minutes at low fire on a 9 minute cycle (so, 6.5 cycles/hour.) The burner engages when supply (and return) drops to 92, and disengages when it reaches 112.
On a side note, this seems like a rather low heat loss...
Technically
Technically you are more than 6 cycles per hour. In reality that seems pretty good. With such a light load, it seems unavoidable."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
