If our community has helped you, please consider making a contribution to support this website.  Thanks!
Pressuretrol controller Honeywell PA404A 1009
                    Lucho
                    Member Posts: 1
                                  in Gas Heating
                    How can setup pressuretrol controller PA404A 1009?
I saw that my heating system turn on in the next setups, but I don't know which is the correct?
1. Differential dial on 2 and PSI on 9
2. Differential dial on 3 and PSI on 8
3. Differential dial on 4 and PSI on 6.5
4. Differential dial on 5 and PSI on 6
Thank you
Luis villegas
Thank you
Luis villegas
            Pressure
 Differential 1.
 1 PSI.
 The lower, the better. But, these controls have trouble running too low. So, stick to the above numbers.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
