Pressuretrol controller Honeywell PA404A 1009
Lucho
Member Posts: 1
in Gas Heating
How can setup pressuretrol controller PA404A 1009?
I saw that my heating system turn on in the next setups, but I don't know which is the correct?
1. Differential dial on 2 and PSI on 9
2. Differential dial on 3 and PSI on 8
3. Differential dial on 4 and PSI on 6.5
4. Differential dial on 5 and PSI on 6
Thank you
Luis villegas
Thank you
Luis villegas
Pressure
Differential 1.
1 PSI.
The lower, the better. But, these controls have trouble running too low. So, stick to the above numbers.0
