Guard Dog Wiring...
I am wire up one of these for the 1st time... Buderus G124xII  w/ the RB-24E w/ the Honeywell 8148E aquastat.
 The diagram they give is pretty good except for 2 things I am not sure on....
>Do I remove the jumper between W and Z?
> Not sure where to wire in the 2nd yellow wire  going to TR?
<a href="http://s3.pexsupply.com/manuals/1320960093621/67941_PROD_FILE.pdf">http://s3.pexsupply.com/manuals/1320960093621/67941_PROD_FILE.pdf</a>
page 4 at the bottom
ty,kcopp
  • JStar
    JStar Member Posts: 2,752
    Wiring
    Keep the jumper.
    The yellow wires interrupt the burner control in series. Treat it like a limit/safety.
  • kcopp
    kcopp Member Posts: 4,628
    that helps....
    a little bit but I need to know exactly were I put that wire.
  • Paul48
    Paul48 Member Posts: 4,469
    One
    to TR, one to B1, like the drawing. Blow the drawing up, to make it clearer.
