Advise on my header before hooking up to the mains
ctjomac
Member Posts: 52
I finally pulled the 1953 monster out of our basement and began installing this Burnham MST396. I've read alot here abut drop headers and built my first one. I did NOT have as much fun as I thought I would, but the first attempt is near completion. There's probably still 1-2 weeks before I have to turn on the steam, so if this thing needs adjusted, PLEASE tell me so I can correct it~!. I guess my 2 main concerns are: The header slants from front towards the back about 1" while the boiler is level in all directions ....and : I thought I read somewhere on here (awhile back) that there should be a certain space between the header Tees, but I can't find it now....will this be a noise r performance issue for me?
As always, Thanks so much for this site and the Great advise everyone puts forward.
Joe
Joe
Nice!
Where do you live? I'll hire you!0 -
Header
Nice work, I would add some hangers, (clevis or teardrop hangers for support) but other than that it looks real nice0 -
Is this the thread you're looking for?
http://www.heatinghelp.com/forum-thread/140318/Burnham-IN11-Header-Question
Personally I would have put the union between the inlets and outlets. You always want the boiler risers to be close together and then the greatest separation between the boiler risers and main risers.Just another DIYer | King of Prussia, PA
Nice job.
That should work out just fine! You can be proud of that work.gwgillplumbingandheating.com
Agreed
that drop header would do any of us proud.
I can see you didn't have much room to put a longer nipple in the header between the boiler risers and the steam main connections, but your use of full-size nipples at the steam main takeoffs and bell reducers above should keep the velocity down to where you shouldn't have a problem.
And you did it on the first try- GREAT!All Steamed Up, Inc.
Consulting0 -
Well...
Ya done good, pilgrim.
Bob Boan
Nice Job.....
That would be the best header on a steam boiler in all of Chicago, from what I've seen! BTW those dimensions you were wondering about....a miniumum of twice the header diameter between each takeoff and between the last take off and the drip and 3 times the diameter between the last boiler riser connection and the first supply take off. However, as Steamhead said, keeping the take offs full size will help prevent water on the bottom of the header from lifting into the takeoffs.There was an error rendering this rich post.
Drop headers rock
Looks nice. Sure is a lot of work, and manly work at that. Welcome to the ranks of dead men who refuse to die.0 -
Drop headers rock
Y Fitting
I gotta ask, what is the Y fitting in the middle of the vertical equalizer for?
Thanks
Richard.There was an error rendering this rich post.
It looks like the Y
will become the top of The Hartford Loop. And an isolation valve. Nice touch.0 -
Y is the preferred Hartford connection
Most companies currently specify a close nipple at the Hartford connection. Some still include the option of using a Y fitting at that same point. In the past the Y fitting was the preferred method. I don't know why things drifted away, perhaps the difficulty in finding Y fittings?Dave in Quad Cities, America
http://grandviewdavenport.com0 -
I give up.
Y is it? :-)Just another DIYer | King of Prussia, PA
- 116 Geothermal
