Here We Go Again
Hoog23
Member Posts: 19
Last year we converted from oil to gas and installed a Smith G8 Steam boiler with an EZ-Gas. So long story short we sold that house and bought another one.
The 'new' house has the original mid-80's gas hot water boiler and a 2nd boiler was installed mid-90's when the basement was finished. Also has a 10 yr old smith gas water heater.
5 zones. I would trash the 2nd boiler.
House has standard baseboard copper finned radiators.
Chimney has a steal liner (it's not masonry).
What are my options?
Would it make sense to do another G8 (hot water) with and EZ-Gas burner?
Burnham ES2? (Does the liner need to be insulated?).
I'm researching the mod-con idea. I do have a outside wall in the boiler room next to the chimney that is not near any windows that should be easy to penetrate.
I"d keep one old one
as a back up and/or for heavy loads and baseload with a little modcon.There was an error rendering this rich post.
Old boilers:
I'd trash them both, go with a Mod/Con, direct vented out the side, and pipe allowances for a future Indirect.
I wouldn't want that Gar-Baage' in MY cellar.
MO.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
