Old Bryant Boiler Age
a3inverter
Member Posts: 64
Trying to determine the age of an old Bryant gas-fired steam boiler.
Model is 4-244
Series A
Serial #18L32757
We checked with the town and they see no permits for replacement back to the early 70's...so it's possible that it is older than that.
Any help or guidance you could provide would be appreciated.
Model is 4-244
Series A
Serial #18L32757
Old Bryant Boiler
Hi - A reference to a Bryant 244 is listed on page A8 in the following link :
http://www.heatinghelp.com/files/articles/936/199.pdf
In the middle of the page it shows a Model 245 with a note "(Model 244 The Same)"
The link above and reference is from the Beacon Boiler Reference Book 1959 -1972 so that would make it seem that your boiler was pre -1972 which corresponds to the town's (lack of) permit information.
I don't know what your plans are for this boiler but you might want to seriously consider replacing it as boilers from that time weren't very fuel efficient. (They didn't have to be as heating oil in those days was around $0.15 a gallon!)
- Rod
The Beacon Boiler Reference Book can be found in the "Library" section of the "Resources" tab found at the top of this page.0 -
Thanks Rod!
The plan is to replace it, just a question of doing it now or waiting until spring.0
- 120 Geothermal
