Natural Gas vent to chimney.
RobLC
RobLC Member Posts: 93
Remove the exhaust vent from the chimney and a piece of the liner has broken off the bricks of chimney.
You can see and touch where if broke off.
The piece that broke off is about 12" in height.
What kind of mortar or cement can we use to repair this.
Type S, maybe Type O or is there something special for this application.
Thank you for your help.
  • RobLC
    It's a Natural Gas Boiler vent.
  • JStar
    JStar Member Posts: 2,752
    Chimney
    You can fix that one piece, but that's not a good sign for the rest of the chimney. Can you drop a steel liner?
  • gennady
    gennady Member Posts: 840
    Chimney lining
    Chimneys serving gas boilers must have stainless steel liner installed
  • Paul Pollets
    Paul Pollets Member Posts: 3,669
    Code
    Our WA state code allows flexible aluminum liners for gas venting, stainless steel for oil appliances.
  • RobLC
    Thanks for the help...
    Thank you for answering my question. The liner is about 10 or 12 inches wide, a chute that goes straight to the top of the chimney. It's an off-white color.
    Probably could drop a steel liner inside (maybe flexible).
    Steel liner only for gas appliance makes sense.
