tubing question
bill_105
Member Posts: 429
What are the concerns of using oxygen barrier tubing for a domestic water supply pipe?
None...
Health wise, it is the same plastic as non barrier PEX, except for the EVOH barrier.
Most manufacturers don't get their heating tubing certified (although a few do) for potable water applications. It is a VERY EX$PEN$IVE proposition, hence they don't get it dually certified.
I ran HePEX for potable water in my cabin, and I've not suffered any ill effects.
Best to check with the specific manufacturer if in doubt.
If you get caught by an inspector installing non NSF approved piping in a potable water application, they WILL make you take it out, regardless.
METhere was an error rendering this rich post.
What a coincidence
I just read on a piece of hePex ,not for use with potable water. As a result, the question.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
