tubing question
bill_105
Member Posts: 429
What are the concerns of using oxygen barrier tubing for a domestic water supply pipe?
None...
Health wise, it is the same plastic as non barrier PEX, except for the EVOH barrier.
Most manufacturers don't get their heating tubing certified (although a few do) for potable water applications. It is a VERY EX$PEN$IVE proposition, hence they don't get it dually certified.
I ran HePEX for potable water in my cabin, and I've not suffered any ill effects.
Best to check with the specific manufacturer if in doubt.
If you get caught by an inspector installing non NSF approved piping in a potable water application, they WILL make you take it out, regardless.
MEIt's not so much a case of "You got what you paid for", as it is a matter of "You DIDN'T get what you DIDN'T pay for, and you're NOT going to get what you thought you were in the way of comfort". Borrowed from Heatboy.0 -
What a coincidence
I just read on a piece of hePex ,not for use with potable water. As a result, the question.0
- 120.3K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 30 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 152 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 736 Plumbing
- 5.2K Radiant Heating
- 357 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 70 Job Opportunities
- 14 Recall Announcements
