Copper Near Boiler Piping
Ted_Ryan
Member Posts: 36
Does a plumber that has used copper to replace near boiler piping in the past, automatically move himself to the "knucklehead" (Dan's words) pile and therefor should not be asked for a proposal to replace that same steam boiler?
Plumber
I wouldn't trust him, unless he's willing to change, and do the job right.0 -
Agreed
find a real Steam Man.All Steamed Up, Inc.
Consulting0 -
Copper
Frank, What would be the downside of copper if you Sil-fos'ed the joints ?There was an error rendering this rich post.
Find someone else.
Copper is not the choice for near boiler piping. It expands more than steel and there is no way to do a true swing joint if all the joints are rigidly soldered together.gwgillplumbingandheating.com
Hmmm
Only in the Lost Art of Hot Water Heating! To me copper in near boiler piping shows a general lack of knowledge in steam heating.0 -
how about soft copper ?
I've long wondered about letting stuff just flex to deal with thermal expansions. Something like your truck's exhaust ?0 -
If its not broke
Don't fix it. Iron pipe and threaded fittings have worked for years on steam boilers and are easy to find.
To be honest, I used iron on my header but copper returns and a copper 2" equalizer and when I had to buy a length of 2" copper pipe just for the stupid equalizer I was sorry I didn't use iron for it.
I have to wonder though while we're on the subject. I used two unions on the 2" risers out of my boiler, one per riser. I'm thinking those unions also allow for the pipe to turn somewhat?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
don't fix it
If its not broke
ChrisJ gives practical advice but it's why we associate with dead men. In the seventies, hydrotherm and slantfin tried to develop cheaper methods to distribute steam. The goal was to sell boilers. Hopefully homebuyers would pay extra for wet heat and commercial buildings would use boilers for perimeter heating. BTW you see wrong iron fittings often.0 -
Copper??
The other reason not to use copper on the steam side is steam will leach copper from the tubing and those copper molecules will end up in the boiler causing galvanic reactions.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 987 Plumbing
- 389 Solar
