Copper Near Boiler Piping
Does a plumber that has used copper to replace near boiler piping in the past, automatically move himself to the "knucklehead" (Dan's words) pile and therefor should not be asked for a proposal to replace that same steam boiler?
  • JStar
    JStar Member Posts: 2,752
    Plumber
    I wouldn't trust him, unless he's willing to change, and do the job right.
    Steamhead Member Posts: 18,252
    Agreed
    find a real Steam Man.
    Consulting
  • bob_46
    bob_46 Member Posts: 813
    Copper
    Frank, What would be the downside of copper if you Sil-fos'ed the joints ?
  • gerry gill
    gerry gill Member Posts: 3,083
    Find someone else.
    Copper is not the choice for near boiler piping. It expands more than steel and there is no way to do a true swing joint if all the joints are rigidly soldered together.
    gwgillplumbingandheating.com
  • fixitguy
    fixitguy Member Posts: 99
    Hmmm
    Only in the Lost Art of Hot Water Heating! To me copper in near boiler piping shows a general lack of knowledge in steam heating.
  • jumper
    jumper Member Posts: 2,502
    how about soft copper ?
    I've long wondered about letting stuff just flex to deal with thermal expansions. Something like your truck's exhaust ?
  • ChrisJ
    ChrisJ Member Posts: 17,097
    edited September 2012
    If its not broke
    Don't fix it.  Iron pipe and threaded fittings have worked for years on steam boilers and are easy to find.
    To be honest,  I used iron on my header but copper returns and a copper 2" equalizer and when I had to buy a length of 2" copper pipe just for the stupid equalizer I was sorry I didn't use iron for it.
    I have to wonder though while we're on the subject.  I used two unions on the 2" risers out of my boiler, one per riser.  I'm thinking those unions also allow for the pipe to turn somewhat?
  • jumper
    don't fix it
    If its not broke
    ChrisJ gives practical advice but it's why we associate with dead men. In the seventies, hydrotherm and slantfin tried to develop cheaper methods to distribute steam. The goal was to sell boilers. Hopefully homebuyers would pay extra for wet heat and commercial buildings would use boilers for perimeter heating. BTW you see wrong iron fittings often.
  • Jason_13
    Jason_13 Member Posts: 305
    Copper??
    The other reason not to use copper on the steam side is steam will leach copper from the tubing and those copper molecules will end up in the boiler causing galvanic reactions.
