Smallest top vent oil boiler?
bugaboo
bugaboo Member Posts: 14
I am trying to see what options may be out there that I've overlooked.
Due to space and layout constraints I need a top vent boiler. Due to the low heat load I am looking for low output.
What is out there, and what is the feedback on it? I did see the Burnham V8H-2, but have heard it has issues with sooting due to the small size.
Thanks!
  • icesailor
    icesailor Member Posts: 7,260
    Venting:
    By "top venting", I assume that you mean the exhaust.
    Weil-Mclain WGO Gold boilers vent out either the back or the side/end. They are quieter when vented out the back, and they are easier to clean when vented out the back.
    It's a "Pin" type boiler. Pin Type boilers seem to be considered junk by many now. They put fins on baseboard heaters. You can get the same output with a lot of enclosed pipe but a lot less with fins on the pipe. Triple pass boilers have no pins. Nice for techs that hate to clean boilers. Especially cold start boilers that fill up with Kibbles & Bits and have to be knocked out. With warm start, boiler temperatures kept at over 140, you can go for a few years between thorough cleanings.Though I want to clean them annually.
    Others here will give you other suggestions. Where I work, the choices are limited and I find the WGO, WGTO's work best.
  • bugaboo
    Yes
    You are correct, I do mean top exhaust, or top flue.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,591
    How about?
    How about a System 2000? Burnham LE?
  • bugaboo
    System 2000?
    Okay, I have read about System 2000, but have no experience with them.
    I have looked at the site, and I can't tell where the flue is. It looks like it's in the back.
    I am interested in the stackable setup, but the overall dimensions are critical. I would be looking at small water tanks, probably the 40 gallon lowboy. I could possibly do the stackable, even with the rear flue, depending on where the flue is.
  • Robert O'Brien
    System2000
    Frontier vents on top right
