Shops to Strip and repaint radiators
I'm renovating a prewar apartment in Brooklyn and need to have three radiators stripped and repainted. Any recommendations for shops that will do this? Ideally they'd pick up and disconnect/reconnect them too. Pix and specs are on the attached in case that's helpful.
Thank you.
  • Rod
    Rod Posts: 2,067
    Repainting radiators
    Hi- Unfortunately  i very much doubt if you will find someone that disconnects radiators, hauls them away, strips and paints them and then  re installs them.   You might  call around and talk to powder coaters as they might know of some one that did this.
    If it were me i think would consider just painting them myself. Powder coating does a very nice job but can be on the expensive side.  Here a link to a discussion on painting radiators     http://www.heatinghelp.com/article/322/Steam-Radiators/1585/How-to-Paint-an-Old-Radiator
    You might also want to "Search the Wall" button to the right, just under the headings of this page and type in Painting Radiators.
    - Rod
    Steamhead Member Posts: 18,502
    I know an excellent shop in Baltimore that does this
    but the travel time would be a problem......... ;-)
    Consulting
