Shops to Strip and repaint radiators
velobook
Member Posts: 1
I'm renovating a prewar apartment in Brooklyn and need to have three radiators stripped and repainted. Any recommendations for shops that will do this? Ideally they'd pick up and disconnect/reconnect them too. Pix and specs are on the attached in case that's helpful.
Thank you.
Thank you.
Repainting radiators
Hi- Unfortunately i very much doubt if you will find someone that disconnects radiators, hauls them away, strips and paints them and then re installs them. You might call around and talk to powder coaters as they might know of some one that did this.
If it were me i think would consider just painting them myself. Powder coating does a very nice job but can be on the expensive side. Here a link to a discussion on painting radiators http://www.heatinghelp.com/article/322/Steam-Radiators/1585/How-to-Paint-an-Old-Radiator
You might also want to "Search the Wall" button to the right, just under the headings of this page and type in Painting Radiators.
- Rod0 -
I know an excellent shop in Baltimore that does this
but the travel time would be a problem......... ;-)All Steamed Up, Inc.
Consulting0
- 120 Geothermal
- 394 Solar
