Millivolt conversion
fixitguy
fixitguy Member Posts: 97
I'm converting a Peerless 63-04L to millivolt, does anyone have a clue as to which gas valve to use?
  • Henry
    Henry Member Posts: 998
    WHY!
    You will be using gas for nothing gained! You are lowering your system efficiency!
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,417
    Unless you are Amish
    it is not a good idea. Voids warranty and causes liability issues as well as violates gas codes.
    cell # 413-841-6726
  • fixitguy
    makes perfect sense
    #1 The system runs without power, maybe in some places the power never goes out, but around here it does a couple of times each winter. #2 In the northeast, a standing pilot is not a bad thing, lots of damp basements and rusting boilers. #3 In my experience, spark boxes fail on weekends and holidays, when the suppliers are closed.
  • gerry gill
    gerry gill Member Posts: 3,082
    the reason more people arn't touching this thread
    is that we are not supposed to do what you suggest..that said, many of us have done it..we have areas here that will sometimes lose power for a couple days straight in winter..so i know where your going with this.
    gwgillplumbingandheating.com
  • fixitguy
    Job done
    Problem solved. simpler system at the least. PP mount fits in place of spark plug perfectly.
  • Tim McElwain
    Tim McElwain Member Posts: 4,656
    In 1979 the mandate came
    for dual seated gas valves to replace all single seated valves being manufactured from that time forward. This was the sad end of Powerpile systems, they did however allow some transition using a back up safety such as a extra limit set to around 230 degrees F. Or in the case of steam wiring in an additional pressuretrol to kill the millivolt feed to the pilotstat portion of the gas valve in the event of over pressure. So you would have the normal P'trol set to say 2lbs off .5 on and the safety to shut off at 14 lbs back on at 9 lbs. Seeing as you have already made the change I suggest you do this for added safety and for the sake of at least offering some redundancy to the system. Honeywell makes a junction block Q313B generator that will make wiring this easier. If you need any assistance contact me at gastc@cox.net .
  • fixitguy
    great
    thanks tim, thats useful information
  • Gordo
    Gordo Member Posts: 857
    Thank You Tim
    for all that you have done here.
