HELP
i am installing a chilled water fan coil and i am looking for a 3 way modulating valve. i found valves that will give me a to b or a to b and c but not a to b or a to c modulating.
  • Paul48
    Paul48 Member Posts: 4,469
    What
    are you modulating? Pressure, temperature, flow? How do you want to control it?
  • berdss
    berdss Member Posts: 2
    both temp and humidity.
    i will be having a control that i can set temp and humidity.
  • SWEI
    SWEI Member Posts: 7,342
    3-way valve
    Check out the Belimo CCV line.  Wide range of sizes and actuators, pressure-independent designs, even a new 6-way for reversible chilled beams.
