HELP
berdss
Member Posts: 2
i am installing a chilled water fan coil and i am looking for a 3 way modulating valve. i found valves that will give me a to b or a to b and c but not a to b or a to c modulating.
What
are you modulating? Pressure, temperature, flow? How do you want to control it?0 -
both temp and humidity.
i will be having a control that i can set temp and humidity.0 -
3-way valve
Check out the Belimo CCV line. Wide range of sizes and actuators, pressure-independent designs, even a new 6-way for reversible chilled beams.0
- 120 Geothermal
- 394 Solar
