Pri/Sec piping single stage boiler controls ?
Paul_34
Paul_34 Member Posts: 31
What control does most guys run on a copper fin basboard with primary and secondary pipe with single stage cast boiler with reset.
  • CMadatMe
    CMadatMe Member Posts: 3,086
    ODR
    If your going to zone and use Taco Zone Controls just use the EXP versions and plug in the PC700 card..If existing Taco now has the Fuel Mizer...
  • JStar
    JStar Member Posts: 2,752
    Simple
    If you want to keep it incredibly simple, you can use a Switching Relay to let the thermostat turn on the system pump, and close the reset control's demand contacts. Then the reset control will turn on the boiler pump and burners.
