Pri/Sec piping single stage boiler controls ?
Paul_34
Member Posts: 31
What control does most guys run on a copper fin basboard with primary and secondary pipe with single stage cast boiler with reset.
ODR
If your going to zone and use Taco Zone Controls just use the EXP versions and plug in the PC700 card..If existing Taco now has the Fuel Mizer...There was an error rendering this rich post.
Simple
If you want to keep it incredibly simple, you can use a Switching Relay to let the thermostat turn on the system pump, and close the reset control's demand contacts. Then the reset control will turn on the boiler pump and burners.0
- 120 Geothermal
- 394 Solar
